1997 Ford Contour Cold Start Stall
MZIMMER5
I have a 1997 Contour with about 137000 miles on it. On cold mornings when I start the car, it will idle for a minute then stall. It starts right back up and every once in a while will stall out again, however it is usually fine after the first occurence. I have scanned the cpu to no avail and sent it to both Ford and private mechanics to no avail, no codes and no answers. I do rember one mechanic stating that it might be a maf sensor, and I have read your other forums about the feul pump and filter. I was wondering what you might suggest, as I have had both checked and evrything has passed with flying colors.
Aug 4, 2006 at 9:06 PM
SERVICE WRITER
  • 9,123 POSTS
This may be of no value, but want to pass it along. We had one that was similiar if I remember right. The check engine light was lit and helped in finding the problem. There was a vacuum hose that runs from the booster to the manifold that had rubbing on another line or somthing. The leak was hard to find. Using a smoke machine we narrowed it down, but had to move the line around to get it to show.
Aug 5, 2006 at 6:58 AM
Suggested Repair
Inspect the vacuum hose from the brake booster to the intake manifold for a rub-through leak. A smoke test may be needed, and the hose may have to be moved to reveal an intermittent leak.
Conversation Summary
A 1997 Ford Contour with about 137,000 miles stalls after idling about a minute on cold mornings, then usually restarts and runs fine. Scans showed no codes, and checks of the MAF sensor, fuel pump, and filter found nothing. An expert recalled a similar stall caused by a hard-to-find vacuum leak in the hose from the brake booster to the manifold, located with a smoke machine.
