Shuts off while driving
165,000 MILES • AUTOMATIC
JESSICA LYNN
Just bought the car was working fine up to about a week ago. it just shut off then it was running fine after that. then on Friday I was coming home and it just shut off on me. I replaced the relay switch and fuel filter, but there is no gas going through to the engine the pump is only like three months old. I am running out of options I need some advice.
Jul 16, 2017 at 10:02 PM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge it may be the wrong/bad pump. it also may be a security issue which try another key not a new one if you have one. check all fuses under hood as well. See links:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Jul 17, 2017 at 12:43 AM
