1998 Ford Contour Stalls and Overheats
HERRERA
I have a 1998 ford contour. The vehicle starts and stutters while the vehicle is on. If I press the brake repeatedly the car tries to stall and if I drive the car down the road the car bogs down and smokes just a little and the temp on the car raises to past normal and near the red where it is HOT. I had a frind who new a mechanic to look at it and he cleaned the injectors and checked the spark plugs and returned the vehicle and as I drove it down the road I noticed no change and the car is still not working properly.
Apr 25, 2007 at 2:14 PM
SERVICE WRITER
  • 9,123 POSTS
Did you say "had" a friend?
Have the codes checked for starters, don't fool around waiting or your liable to cook the engine.IMHO.
I "think" you may have 2 separate problems. I have seen of these with a cracked vacuum tube that runs from the brake booster and down tha firewall.
But until we have some codes, it's just acemdemic.
Apr 25, 2007 at 2:32 PM
Suggested Repair
Scan for diagnostic trouble codes immediately and avoid further driving so the engine is not damaged by overheating. Inspect the vacuum hose running from the brake booster down the firewall for cracks, which can cause stalling when the brake is applied. Treat the overheating and the brake-related stall as possibly separate problems.
Conversation Summary
The owner of a 1998 Ford Contour reports stuttering, stalling when the brake is pressed repeatedly, bogging, light smoke, and overheating while driving. Cleaning the injectors and checking the spark plugs did not help. The expert advises scanning for codes right away and mentions a possible cracked vacuum tube from the brake booster, while noting the issues may be separate.
