1998 Ford Contour GL Stops Running
LSHIPLEY
I have a 1998 Ford Contour GL with 93,000 miles. I have had the car for about 1 1/2 years but i have driven it less than 2,500 hundred miles. This is because i can't keep it running. The car will drive fine for two or three days and then it will just stop completely. No ticking, clicking, squeling, or any other weird noises. It just won't move. I have had the starter, fuel filter, head gasket, and a lot of other stuff done to it, to no avail. I have had it tested and they tell me that no problems show up on the computer. Someone told me to check out the fuel cell sensor. What is that and where is it. Or can someone tell me how to fix this car, please.
Mar 10, 2006 at 11:33 AM
PEPPERMRJ
  • 1,158 POSTS
If it dies when running it could be a bad crankshaft position sensor.
The fuel sensor or rollover switch can be reset but would not reset itself. Check your owners manual for it's location.
Good luck and let us know. :)
Mar 11, 2006 at 1:07 PM
Suggested Repair
If the engine dies while running, check the crankshaft position sensor. Also inspect the fuel sensor or rollover switch, which can be reset but would not reset itself; see the owner's manual for its location.
Conversation Summary
The owner of a 1998 Ford Contour GL says the car runs fine for two or three days, then stops completely with no unusual noises. The starter, fuel filter, head gasket, and other parts have been replaced, and no computer codes appear. The owner asked about a fuel cell sensor. An expert said a bad crankshaft position sensor could cause it to die while running, and noted that the fuel sensor or rollover switch can be reset but would not reset itself; its location is in the owner's manual.
