1998 Ford Contour
MANDERSONSET
  • 1998 FORD CONTOUR
Electrical problem
1998 Ford Contour 6 cyl Two Wheel Drive Manual
i just installed a used v6 in my car. Everything is hooked up. Swapped coil, crank sensor, cam sensor, etc. I have no spark to plugs. Any ideas?
Friday, February 5th, 2010 AT 9:52 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Saturday, February 6th, 2010 AT 8:13 AM
