Computer problem
1998 Ford Contour 6 cyl Front Wheel Drive Manual
Where is the computer located? Ineed to switch it off to repace the ignition
Thursday, November 13th, 2008 AT 3:27 PM
DAVE H
MECHANIC
You need to disconnect the battery. That will shut down computer. The car may feel/handle a little different for the first few miles you drive it after you finished working an reconnected the battery. The computer has to go through a relearn cycle.
