1997 Ford Contour turn signals dont work
88,847 MILES • 4 CYL • 2WD • AUTOMATIC
NANAE34
my turning signals started working park of the time and now they r not working.i tried to locate the flasher but cant locate it.the haszard quit working to. the dimmer light works which is on the same turning signal arm..i was told i need a new arm which would cost me 216.00. i would like to try the flasher first. also sometimes when i am driving the steering will lock up and then the car shuts off.
Jan 5, 2008 at 2:20 AM
BMRFIXIT
  • 19,053 POSTS
[quote:10c2716d67="nanae34"]Electrical problem
1997 Ford Contour 4 cyl Two Wheel Drive Automatic 088847 miles
my turning signals started working park of the time and now they r not working.i tried to locate the flasher but cant locate it.the haszard quit working to. the dimmer light works which is on the same turning signal arm..i was told i need a new arm which would cost me 216.00. i would like to try the flasher first. also sometimes when i am driving the steering will lock up and then the car shuts off.[/quote:10c2716d67]
flasher under steering area
looks like a relay
switch about 170 $ parts and labor
Jan 5, 2008 at 1:57 PM
