1997 Ford Contour turn signal
1997 FORD CONTOUR
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOLSON_54313
I broke my passenger side turn signal assembly. How do I take the broken one off the car to replace?
Sep 28, 2009 at 7:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Disconnect the negative battery cable.
Remove the upper steering column cover.
Release the locking tab securing the multi-function switch to the steering column.
Slide the switch from the steering column.
Unplug the wiring harness connector from the multi-function switch.
INSTALLATION:
If the multi-function switch is being replaced, transfer the indicator flasher from the old switch.
Reconnect the wiring harness connector to the multi-function switch.
Slide the switch into position and make sure the locking tab is fully seated.
Reinstall the upper steering column cover.
Reconnect the negative battery cable.
Check the multi-function switch for proper operation.
Sep 28, 2009 at 9:13 PM
