1995 Ford Contour
GREENE77
  • 1995 FORD CONTOUR
  • 4 CYL
  • 233,567 MILES
I have a 1995 Ford Contour, is there a drain plug on the transmission pan for this car
Saturday, December 13th, 2008 AT 10:22 AM
DAVE H
  • 13,384 POSTS
DRAINING & REFILLING
CD4E
Raise and support vehicle. Place drain pan under transmission. Remove transmission drain plug and drain fluid from transmission. Install transmission drain plug.
Add 5 qts. (4.7L) ATF. Start engine and run at idle for five (5) minutes. Shift transmission through all gears during 5 minute time period. Remove transmission drain plug and drain fluid from transmission.
Install transmission drain plug and tighten to specification. Add 6 qts. (5.7L) ATF. Start engine and run through all gears. Check fluid and top off as required.
Sunday, December 14th, 2008 AT 8:56 PM
