1995 Ford Contour Wont shift into overdrive
161,894 MILES • 4 CYL • FWD • AUTOMATIC
MASADLER
When I travel on the highway my cor whines when it shifts into 2nd and 3rd gear and then around 55-65 mph it continues to whine and doesn't shift into overdrive. I was told that my transmission is going bad and I would only be able to drive it short and slow distances. I have not done a transmission service in over two years. could this be a problem?
Oct 27, 2008 at 11:57 AM
KHLOW2008
  • 41,812 POSTS
Hi masadler,
Whining noises are usually due to worn bearings or bushes and it is a sign of inefficient lubrications, wear and tear due to old age. Two years is not the problem, it is the amount of travelling that is the main factor.
If you do not have enough fluid in the system, it might not upshift to OD, check it first.
Oct 29, 2008 at 3:45 AM
MASADLER
I had all the fluids checked and they are all good.
Oct 29, 2008 at 11:34 AM
KHLOW2008
  • 41,812 POSTS
Hi masadler,
Since the fluids are good and level correct, I would suggest getting a scan done to find if there are any DATA FREEZE FRAME stored in memory of the PCM. Scannng can be done free at your local Autozone outlet.
This might help in diagnosing the OD not functioning problem. As to the whining, it should be internal fault of the trans and I don't think there is anything you can do about it except get a rebuild or replacement.
Oct 29, 2008 at 11:49 PM
