1989 Ford Bronco No Gear Engagement
ELVISISTHEMAN
i hav 89 ford bronco full size 160000 trans mission just stopped pulling all at once with no warning i changed fluid and filter and still it doesnt even try to go into gear i get no response from tranny at all does anyone no what might of happened
Sep 1, 2007 at 5:57 PM
  • 75,988 POSTS
[quote:2c056c5fbe="elvisistheman"]i hav 89 ford bronco full size 160000 trans mission just stopped pulling all at once with no warning i changed fluid and filter and still it doesnt even try to go into gear i get no response from tranny at all does anyone no what might of happened[/quote:2c056c5fbe]
Sounds internal like clutches and bands
Sep 1, 2007 at 10:39 PM
Suggested Repair
Because a fluid and filter change did not restore any gear engagement, suspect an internal transmission failure involving the clutches and bands. Have the transmission inspected for internal damage and plan on a rebuild or replacement if confirmed.
Conversation Summary
The owner of a 1989 full-size Ford Bronco with 160,000 miles said the transmission suddenly stopped pulling with no warning. Changing the fluid and filter produced no response and the transmission still would not try to go into gear. The expert said the problem sounds internal, involving the clutches and bands.
