1979 Ford Bronco Dies in Gear
KCOVEY
Year: 1979
Make: Ford
Model: Bronco (Full Size)
Mileage: Unknown at this time
Engine Size: 351-M
Problem 1 - I installed a new engine 351m w/ original intake manifold, and new carburetor. Engine runs fine when in "Park", but when I put it in gear (R, D or 2, 1) the engine dies, any ideas?
Problem 2 - I have a vacuum advance on my distribrature, and power breaks. The vacuum advance doesn’t seem to advance when I accelerate, and the power breaks (Booster) doesn’t seem to have enough vacuum to work correctly. How much vacuum pressure should there be on the entire system for everything to work correctly?
Jul 6, 2007 at 4:57 AM
MERLIN2021
  • 17,250 POSTS
Seems to me you main problem is finding a vacuum leak! With a vacuum gauge reading on a good engine is 28Hg max
Get a cN OF GUMOUT AND SPRAY AROUND TILL THE IDLE CHANGES, YOU HAVE LOCATED A LEAK!
Sorry hit caps lock!
Jul 6, 2007 at 9:34 AM
Suggested Repair
Check for a vacuum leak. Compare manifold vacuum with a gauge (a good engine should reach about 28 inHg maximum) and spray carburetor cleaner around vacuum connections until the idle changes to pinpoint the leak.
Conversation Summary
A 1979 Ford Bronco with a newly installed 351M engine, original intake, and new carburetor idles in Park but dies in gear. Vacuum advance and the power-brake booster also appear to lack vacuum. The expert attributes both issues to a vacuum leak and recommends a vacuum-gauge check plus a spray test to locate the leak.
