1992 Ford Bronco Stalls When Wet
STALTER_C
I have a 1992 Ford Bronco with 154000 miles on it. I had problems with it in the past of it idling rough and then cutting out. That was an easy fix and I changed the fuel filter. But now it has started doing it again, except this time on dry days it starts and runs just fine. But if it is raining or had rained and is still wet. It will start fine but as soon as I start moving forward. The bronco begins to sputter and then she will just cut off.
Mar 25, 2006 at 3:58 AM
LOVESCARS
  • 359 POSTS
try the ignition wires. start the vehicle in the dark,has to be pitch balck and look at the wire you may see some sparking this is one way to identify if the sires are no longer insulated
Mar 25, 2006 at 1:10 PM
Suggested Repair
Inspect the ignition wires for failed insulation. Start the Bronco in complete darkness and look along the wires for visible sparking, which can cause sputtering and stalling when wet.
Conversation Summary
The owner of a 1992 Ford Bronco with 154,000 miles says it starts and runs fine on dry days, but after rain or when wet it starts, then sputters and cuts off once moving. A previous rough-idle and stalling issue was fixed by replacing the fuel filter. The expert recommends checking the ignition wires in the dark for sparking that indicates the insulation has failed.
