1995 Ford Bronco Cranks But Won't Start
JOHNMAIN3RD
1995 eddie bauer ford bronco,185,000...5.0 liter.
truck was running fine. parked in driveway during snowstorm on a slope. truck tries to turn over but will not start. any help greatly apprieciated.
Feb 28, 2007 at 8:17 AM
BOOTDOG
  • 665 POSTS
the first thing to check is the battery. cold weather kills batteries. how old is the battery? have you tried to jump it? let me know and we can go further.
Feb 28, 2007 at 9:50 AM
JOHNMAIN3RD
like I stated the truck trys to turn over. battery is just fine. It won't fire up. any further tips to look into? Please reply
Feb 28, 2007 at 10:05 AM
BOOTDOG
  • 665 POSTS
turn the key to the on position. do you hear the fuel pump running? if so, where does the gas gauge register at. sometimes the fuel sending unit will go bad and give the gauge a faulty reading, which in case, you'll run out of fuel and not know it.
if you don't hear the pump running then tap on the gas tank with a hammer while someone else tries turning the engine over. if it starts then replace the pump. if not check for power going to the fuel pump. if there is power there and the you still can't hear the fuel pump running when the key is in the on position. replace it also
Feb 28, 2007 at 11:34 PM
JOHNMAIN3RD
ok, I do hear the pump i think, "should pump sound be continous? . gas gauge at alittle less than 1/4.
pulled a plug to see if there was spark and there definetley is. how exactly do I check for power at pump? Guidance needed and very appreiciated. while I was trying the plugs I could smell fuel. how do i know if i'm getting fuel at manifold?
Mar 1, 2007 at 7:36 AM
BOOTDOG
  • 665 POSTS
if you hear the pump then we know it's working. it's should sound like a high pitch whine. and no it's not continuous. try putting fuel in the tank to see if the gauge moves. if not replace the fuel sending unit.
Mar 1, 2007 at 11:50 PM
EDDIEBOWER2
[quote:8714462a70="johnmain3rd"]1995 eddie bauer ford bronco,185,000...5.0 liter.
truck was running fine. parked in driveway during snowstorm on a slope. truck tries to turn over but will not start. any help greatly apprieciated.[/quote:8714462a70]
I recently replaced my fuel pump and fuel line filter on my 1996 Exployer. But, it rained heavily today and it will not start. My machanic says that it is most likely my wiring.
Mar 2, 2007 at 5:17 AM
BHUGG
  • 157 POSTS
Start checking the fuses. There is a fuse panel under the hood that has ignition and engine circuit fuses and some relays that could be bad. Check these out. Also check the fuses in the dash. If all the fuses are good, try to switch some of the relays around (make sure they are the same) to see if it is a problem there.
If we help, let us know.
The forum is here to help and we want to know if we are helping.
Give us a vote if we deserve it.
Mar 3, 2007 at 5:39 PM
Suggested Repair
The fuel pump primes with a brief high-pitched whine and spark is present. Add fuel and watch the gauge. If the gauge does not move, replace the fuel sending unit.
Conversation Summary
A 1995 Ford Bronco 5.0 cranks but will not start after sitting on a slope in a snowstorm. The battery was ruled out because it cranks, and the owner reported spark, a fuel smell, a gauge below one-quarter, and a fuel-pump sound. The expert said the pump should whine briefly rather than run continuously, and advised adding fuel to see whether the gauge moves. If it does not, replace the fuel sending unit.
