Should I replace the ignition switch? What would cause all of those problems?
Bobby
Check the under-hood power distribution box fuses and relays. If they are good, inspect the wiring between the interior fuse box and power distribution box for a loose connection. Also disconnect the newly installed stereo and trace related wiring for shorts, bare wires, or loose connections.
A 1991 Ford Bronco lost headlights, dome lights, stereo, cigarette lighter, power door locks, and horn after an aftermarket stereo installation. Interior fuses were good and a new headlight switch did not help, though the systems briefly worked once. Power windows, turn signals, and brake lights still worked. Advice was to disconnect the stereo, check for shorts or loose wiring, and inspect fuses, relays, and connections at the under-hood power distribution box.
