1987 Ford Bronco head lights won't work on my Bronco II
1987 FORD BRONCO
38,000 MILES • 6 CYL • 4WD • MANUAL
DANIELCUTHBERT
I checked the fuses, their fine. What could it be, the parking lights and all other lights work fine.
Apr 29, 2009 at 11:47 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check for power at the headlight switch. If power is OK suspect faulty switch. If power is not OK, inspect wiring for damages/shorts.
Thanks for using 2CarPros.com!
Apr 29, 2009 at 5:58 PM
