My bronco hasnt started ever since I took it mudding I think its a fuel problem cuz if I spray starter fluid in the intake it starts up. Its getting fuel to the motor it wasnt enough pressure so I put a new fuel pump in it and the pressures up but it still wont start. I think it must be an electrical problem because the truck ran perfect before I went mudding in it. Is there any sensors that will cause my truck not to start if they are bad and is it possible my computer may be bad?
SPONSORED LINKS
Tuesday, November 10th, 2009 AT 3:13 PM
MECHANIC
If you have spark and fuel, it should run unless the injectors are not working. When you checked fuel pump pressure, where did you check it from, the fuel rail?
