1992 Ford Bronco Won't crank
REGGIEBRONCO
  • 1992 FORD BRONCO
  • V8
  • 4WD
  • 200,000 MILES
I turn the key and onlt get a cllicking. Changed loose ignition, replaced battery and sylinoid. Truck was running fin unitl it wouldn't crank at all. Suggestions?
Wednesday, December 12th, 2007 AT 9:58 AM
BLACKOP555
  • 10,371 POSTS
Hows the battery? Check the connections for corosion or loose fittings, if thats good check the starter relay.
Wednesday, December 12th, 2007 AT 12:20 PM
JWALTH02
  • 180 POSTS
He said he replaced the battery and solinoid. Try tapping on the starter while someone tries to crank the truck. It sounds like it's sticking. If it's gotten cold where you live that's most likely the case, older starters stick when cold. Let us know how it goes. Good Luck.
Monday, December 17th, 2007 AT 11:25 PM
BLACKOP555
  • 10,371 POSTS
Yes, he may have replaced the battery, but ive ran into several "new" defective batteries. And I misread that he said that he replaced the relay.
Tuesday, December 18th, 2007 AT 6:41 PM
