1990 Ford Bronco won't start
HAZELDO
  • 1990 FORD BRONCO
Engine Mechanical problem
1990 Ford Bronco V8 Four Wheel Drive Automatic
while driving engtine stalled. Wouldn't restart. Have since changed brain, distributor, fuel pump, coil. Any suggestions
Sunday, August 9th, 2009 AT 1:17 AM
Do below to determine if its fuel or spark problem and then get back
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, August 9th, 2009 AT 1:28 AM
