1990 Ford Bronco won't start
CAPTAIN559
  • 1990 FORD BRONCO
  • 6 CYL
  • 4WD
  • MANUAL
  • 12,700 MILES
My Bronco stopped running going down the highway with no indication or noise. It cranks over but no pops, new fuel pump and filter in last year.
Wednesday, March 5th, 2008 AT 1:58 PM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
Check the ignition module.
Wednesday, March 5th, 2008 AT 2:04 PM
