1990 Ford broco extreeme problem
CARRACER302003
  • 1990 FORD BRONCO
I have a 1990 ford bronco and I am having a serious problem with it cutting out running like crap, it dosent do it all the time its just when you go to start it up it takes for ever ( wich it should not because it has not in the past and it is fuel injected) and when you get on the throttle it falls on its face, and as of now it will not start and when turning it over I smell gas fumes extreemly bad and the fuel press regulator has been replaced just for the info thanks
Wednesday, July 11th, 2007 AT 9:11 PM
MERLIN2021
  • 17,250 POSTS
Try the temp sensor.
Saturday, July 21st, 2007 AT 2:00 PM
JPN1212
Ive had a similar problem, you mean the temperature sensor for the engine?
Sunday, May 18th, 2008 AT 7:34 PM
MERLIN2021
  • 17,250 POSTS
Yes it's usually the Engine coolant temp sensor(ECT) or thie Intake air temp sensor, (IAT)
Tuesday, May 20th, 2008 AT 1:33 PM
