HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Bronco
Ignition
No Spark
1989 Ford Bronco no spark
JIM CHEESEMAN
MEMBER
1989 FORD BRONCO
Electrical problem
1989 Ford Bronco 6 cyl Four Wheel Drive Manual 400 00 miles
how do I test ignition coil
Wednesday, September 15th, 2010 AT 11:12 AM
WRENCHTECH
MECHANIC
The most common way is to measure the primary and secondary resistance.
Here is a site than gioves you instructions
SPONSORED LINKS
Wednesday, September 15th, 2010 AT 11:22 AM
Please
login
or
register
to post a reply.
Related No Spark Content
No Spark Unless I Pull The Spout Connector.
I Get Spark One Time And Then Nothing, I Pull The Spout Connector And I Can Get Spark As It Should Be But It Won't Start Unless I Spray...
Asked by
PatrickHanes
1989
FORD BRONCO
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
I Am Getting Fire To The Coil But Not From It. I Have...
I Am Getting Fire To The Coil But Not From It. I Have Replaced The Coil And Still No Fire From Coil To Distributer
Asked by
Anonymous
1 ANSWER
1989
FORD BRONCO
My Bronco Wount Start
Ok I Got A 91 Ford Bronco 5.8l V8 I Replaced The Distributor Ignition Mod. And New Plugs And Wires New Coil And I Have Spark From The Coil...
Asked by
truckdrivendaddy
13 IMAGES
1991
FORD BRONCO
1981 Ford Bronco No Spark
Itz A Cali Emissioned 302 1. I Can Not Locate The Ballast Resistor. 2. I Am Getting No Spark Out Of The Coil. I Have Replaced The Coil...
Asked by
81fsb
1981
FORD BRONCO
Getting No Spark
I Changed Everthing That Deals With Spark Still No Spark
Asked by
dsgb
1992
FORD BRONCO
VIEW MORE
SPONSORED LINKS
Ignition Coil System Test Repair - All Cars
Ignition System Testing
Crankshaft Sensor Replacement
Online car repair manuals
