1988 Ford Bronco Headlights
1988 FORD BRONCO
35,000 MILES • 6 CYL • 4WD • MANUAL
SPITFIRE178
  • 6 POSTS
About 6 months ago both my headlights go out. my truck has no relay for the headlights but I check all my underdash fuses which are all fine. I replace the the headlight switch and the harness because I found there was some damage to the harness. Nothing helped. What I ended up doing just to give my truck working lights, was I spiced into my running lights. Now the same problem has occured. Im not sure If my truck is giving to much power or if I have a bad ground (which I cant find) and advice will do
Jan 11, 2010 at 10:34 AM
BLACKOP555
  • 10,386 POSTS
well what you should do is take out the light switch and verify the switch is properly working. from there for saving trouble shooting i would run all new wires for the headlights and running lights and add my own grounds. i can tell you how to diagnose all this but it would take quite a bit of testing on your part.
Jan 11, 2010 at 11:33 AM
SPITFIRE178
  • 6 POSTS
What I was told is check the power off my battery to see if its givin off too much. But changing all my wiring is another story. I dont have the slightest clue how to do that
Jan 11, 2010 at 11:51 AM
BLACKOP555
  • 10,386 POSTS
if the battery gave off too much power then you will blow the bulbs but that would take a HELL of alot of voltage to be put off by a battery to do that. i can throw you up a wiring diagram all you have to do is get some wire, electrical tape and a switch and a relay and you can control your high and low beams with a toggle switch. off low and high beams with a 3 position swithc.
or we can figure out how to do it with the wiring in the car.
Jan 11, 2010 at 2:47 PM
SPITFIRE178
  • 6 POSTS
Just took out my headlight switch and the harness and the B2 socket of the switch and the harness is burned out. It was the same problem the occured the first time. Im Lost
Jan 17, 2010 at 6:14 AM
BLACKOP555
  • 10,386 POSTS
whats it like? melted? burnt? what
Jan 17, 2010 at 12:47 PM
SPITFIRE178
  • 6 POSTS
The Harness where the wire is is melted and the prong of the headlight switch the corrisponds to the wire is slightly burned
Jan 18, 2010 at 8:29 AM
BLACKOP555
  • 10,386 POSTS
are you using the proper size guage of wire? also is there a continuity between the live wire and the ground wire? sounds like it may be drawing a high amperage. the fuse isnt blowing tho. is it the proper sized amperage. you should try to replace the whole wire from the switch out because it might be damaged causing a high amp draw
Jan 18, 2010 at 8:47 AM
SPITFIRE178
  • 6 POSTS
I checked and its the proper wire. The fuse doesnt blow out either. I would have a real hard time trying to find the wire through the firewall and so on.
Jan 18, 2010 at 1:04 PM
BLACKOP555
  • 10,386 POSTS
you have a floor dImmer right? CHECK that to make sure that the vehicles dimmer switch isnt all corroded up ths coudl cause the vehicles light switch to go out if its arcing
Jan 18, 2010 at 2:55 PM
SPITFIRE178
  • 6 POSTS
no floor dimmer
Jan 19, 2010 at 7:02 AM
BLACKOP555
  • 10,386 POSTS
ok. your going to have to start checking the voltage drops then. are you handy with a multimeter?
Jan 19, 2010 at 9:37 AM
