1984 Ford Bronco coolant leak
1984 FORD BRONCO
189,774 MILES • V8 • 4WD • AUTOMATIC
APRETE
i have an 84 bronco xlt, high mileage, but generally reliable. im getting a radiator fluid leak, seems to be seeping out from around a bolt located approx. 1 1/2 in above the oil filter. maybe you guys have an idea as to what exactly is leaking?
Apr 5, 2009 at 6:25 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:370d79d989="aprete"]Engine Cooling problem
1984 Ford Bronco V8 Four Wheel Drive Automatic 189774 miles
i have an 84 bronco xlt, high mileage, but generally reliable. im getting a radiator fluid leak, seems to be seeping out from around a bolt located approx. 1 1/2 in above the oil filter. maybe you guys have an idea as to what exactly is leaking?[/quote:370d79d989]
Does the bolt have any wires going to it? Can you post a pic of it. The only thing I can think of there would be your engine temp switch.
Apr 5, 2009 at 6:30 AM
