1990 Ford Bronco Coolant emptying
1990 FORD BRONCO
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
SCOOTERBRACY
My Bronco recently began to overheat and the vent quit blowing warm air and began blowing cold air. I checked the coolant level, and it was ridicously low. I had checked it a few weeks back, and the level seemed fine.
I filled the radiator with coolant and the next time I drove it, the same thing happened all over again.
I'm not seeing any visible leaks anywhere, but that coolant has to be going somewhere...any help?
Dec 10, 2008 at 7:23 PM
Test or Replace the thermostat-continues to overheat get it block and pressure tested-
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Dec 10, 2008 at 8:58 PM
TRAVIS650D
  • 8 POSTS
don't forget to check your heater core.. and freeze plugs.. i would bet its just the heater core.. it should be behind the glove box. inside the "black plastic box" i call it the vent assembly...
Jan 17, 2009 at 3:26 AM
