1984 Ford Bronco II Fluid Types
REKRYN
What fluids (type, and all kinds, transmission,steering, etc...) will I need for a 1984 bronco II assuming i change them all?
Mar 9, 2006 at 9:08 AM
RAYHUT
  • 134 POSTS
use motorcraft fluids for fords type f for trans. and any kind of p/s fluid will do, use motorcraft oil 10w 30. use any dot 3 for breaks.if you have a clutch use any clutch fluid.
Mar 9, 2006 at 11:41 PM
Suggested Repair
When servicing a 1984 Ford Bronco II, use Motorcraft Type F transmission fluid, Motorcraft 10W-30 engine oil, any power steering fluid, DOT 3 brake fluid, and clutch fluid if the vehicle has a clutch.
Conversation Summary
The owner asked which fluids to use when changing all fluids on a 1984 Ford Bronco II, including transmission and steering. The expert recommended Motorcraft Type F for the transmission, Motorcraft 10W-30 engine oil, any power steering fluid, DOT 3 brake fluid, and clutch fluid if equipped.
