No takers for my 86 Ford Bronco Fuel pressure?
1986 FORD BRONCO
LUISITO31
  • 6 POSTS
Hi, to all
If somebody had the same problem, need your help or advise, please. Checked all possible problem on this Ford Bronco fuel pressure problem, still cannot meet the desired fuel pressure. How can I test if the fuel pressure regulator is bad or working? Replaced the old fuel pressure regulator with a new one, and it still won't build the pressure the specs required. I've run out of repair ideas. Your help is greatly appreciated. Thanks
Aug 12, 2006 at 9:35 AM
PWKENDALL
  • 11 POSTS
A buddy of mine had a chevy S10 and I helped him replace the water pump. Well while you have all that stuff off, good time to replace the fuel filter. We put everything back and the dang thing would not run right. Come to find out one inch section of fuel line was pinched. Cut off one inch of the hose and reclamped ; runs like a new one. I had a 72 Dodge Monaco and the metal fuel line rubbed the frame and wore a pinhole in the line and it sucked air and would not run right and finally quit running. Just a thought maybe a fuel line.
Aug 13, 2006 at 7:03 PM
MIKEYBDMAN
  • CERTIFIED EXPERT
  • 623 POSTS
[quote:a433d66a7e="luisito31"]Hi, to all
If somebody had the same problem, need your help or advise, please. Checked all possible problem on this Ford Bronco fuel pressure problem, still cannot meet the desired fuel pressure. How can I test if the fuel pressure regulator is bad or working? Replaced the old fuel pressure regulator with a new one, and it still won't build the pressure the specs required. I've run out of repair ideas. Your help is greatly appreciated. Thanks[/quote:a433d66a7e]
Here is the D/O of your fuel pumping system. MAybe it will give you some ideas. I dont know what you have tried other than a pressure regulator. Have you checked the fuel filters for clogging? Replaced or tested either fuel pump?
1985 - 87 4-140 EFI EXCEPT AEROSTAR & V8-302 EFI, EARLY 1986 AEROSTAR 4-140 EFI, 1986 - 87 V6-177 & 1987 6-300
The electric fuel pump system consists of two fuel pumps: a low pressure boost pump mounted in the fuel tank, and a high pressure fuel pump mounted on the frame rail. The low pressure pump is located with its inlets at the bottom of an internal sump in the fuel tank. This design provides for satisfactory fuel pump operation during extreme vehicle maneuvers and steep vehicle attitudes with low tank fill levels.
The low pressure electric fuel pump, Fig. 6, is used to provide pressurized fuel to the inlet of the high pressure pump and helps prevent noise and heating problems. The inlet of the low pressure fuel pump has a nylon filter on it to prevent dirt and other particulate matter from entering the system. Some vehicles use an external resistor in the low pressure pump circuit to reduce operating voltage to 11 volts, Figs. 7 and 8.
The externally mounted high pressure fuel pump, Fig. 9, is capable of supplying 15.9 gallons of fuel per hour at a working pressure of 39 psi. The pump has an internal pressure relief valve to provide over-pressure protection in the event the fuel flow becomes restricted. Over-pressure is restricted to 123 psi and reduced fuel flow will result. The system pressure is controlled by a pressure regulator on the engine.
Aug 13, 2006 at 7:27 PM
