1994 Ford Bronco Fuel Pump Access
DESMOINESBRONCO
Good morning,
Vehicle: 1994 Bronco LT
Milage: 138,000
Engine: 302
Trans: Auto
4WD: Yes
Problem: Fuel Pump
History:
Bypassed ignition to "hotwire" fuel pump using error code port. Fuel pump inergizes intermitantly using percussion therapy on side of tank.
Question:
Is there a work-around method to access fuel tank from above rather than dropping tank?
Nov 1, 2007 at 4:24 AM
FAIRRACING31
  • 150 POSTS
Unless you are willing to cut a hole in the floor of your Bronco. No, you must remove the gas tank to access your fuel pump. Have fun with the gas tank skid plate. :D
Nov 1, 2007 at 4:54 AM
Suggested Repair
Drop the fuel tank to access the fuel pump. There is no practical access from above unless the floor is cut. Remove the gas tank skid plate as part of tank removal.
Conversation Summary
The owner of a 1994 Ford Bronco with an intermittent fuel pump that responds to tapping the tank asked whether the pump can be reached from above without dropping the tank. The expert said the tank must be removed; cutting a hole in the floor is the only alternative, and the skid plate must also be dealt with.
