1995 Ford Aspire Belt will not stay on
101,000 MILES • 4 CYL • FWD • AUTOMATIC
DREWBLAZE
My daughter's car lost a belt. This car does not have power streering or a/c.
I replaced the belt, and once you drove, it would squeel at a high pitch, and then stop, and it seem to run fine.
It was taken on the highway, squeeling all the way - and belt gone!
At idle, it ran very smoothly, and the belt looked like it was aligned perfectly.
What am I doing wrong?
Dec 13, 2007 at 4:16 AM
  • 31,937 POSTS
Hi there,
It sounds like an adjustment problem, If the belt is aligned correctly, adj so there is about 2-3mm deflection and test drive, If it squeals stop and check to see if it is about to let go, There will be a simple answer to this.
Mark (mhpautos)
Dec 13, 2007 at 2:23 PM
