what are the differences? the distributor ecm anything else? recommendations
Mar 16, 2014 at 12:15 AM
KNOWLEDGE IS POWER
EXPERT
You should be fine with that change. The only differences if it's mechanically the same would be external accessories and you may be able to just use the ones off of your 95 motor
