1994 Ford Aerostar Reluctant Start
PEGFRENCH6
I have a 1994 Aerostar 6 cyl. with 110,000 miles. Occasionally it is reluctant to start. After several tries it catches and starts then starts fine for a period of time then is balky again. I had the battery tested and it was good. Last time I had make several tries with the gearshift in neutral and park. When it started it kicked up fine. Could it be the starter?
Peg French
Apr 29, 2007 at 3:09 AM
BLACKOP555
  • 10,386 POSTS
sounds like your solenoid is going in the starter replace and let us know
Apr 29, 2007 at 6:31 AM
PEGFRENCH6
Thanks I'll try that.
Apr 29, 2007 at 7:42 AM
Suggested Repair
Replace the starter solenoid, which is likely failing and causing the intermittent no-start.
Conversation Summary
The owner of a 1994 Ford Aerostar with 110,000 miles reports occasional reluctance to start that clears after several tries, then returns later. The battery tested good, and shifting between park and neutral did not change the behavior. An expert said the starter solenoid is failing and recommended replacing it. The owner agreed to try that.
