1993 Ford Aerostar No-Start Code 64
STIKCLIK1
I have a 93 ford aerostar xl, 3.0 engine with 105,000 miles on it.
It was running a little rough the past week or so and just died while I was driving the other day.
Everything electrical seems fine, cranks but will not start and I can hear the fuel pump turn on.
I ran a poor mans diagnostic test a I believe the code I was given was 64.
I've been surfing for a while and found the results to the code, the problem is that it's not exactly english to me and I'm not sure what I have to do to fix this problem.
What I recieved is " 64-IAT indicated 123 C (254 F) I circuit grounded."
What's the solution?
I greatly appreciate any input
Thank you
R
Mar 18, 2007 at 8:28 AM
TAURUSWHEEL
  • 718 POSTS
That code indicates that either the intake air temperature sensor and or the engine coolant temp sensor are putting out less then minmum voltages, one or both may have failed or a circuit problem may exist..
Mar 18, 2007 at 9:43 AM
Suggested Repair
Code 64 indicates the intake air temperature sensor and/or engine coolant temperature sensor is reading below minimum voltage. Test both sensors and their circuits for a failed sensor or a grounded circuit.
Conversation Summary
A 1993 Ford Aerostar 3.0 ran roughly, then died and would crank but not start while the fuel pump still primed. A poor-man's test returned code 64, described as an IAT reading of 123 C with the circuit grounded. The expert said the IAT and/or coolant temperature sensor is outputting below minimum voltage, so one or both sensors may have failed or a circuit fault may exist.
