1993 Ford Aerostar Speedometer Jumps
GOUDY316
i have a 93 aerostar and i just put a used re-end in it and now my speedometer after 80km starts to shift all over.. i have changed the sencor that is on the re-end that goes to the tranny.. and it still does the same thing.. so thats not the problem.. its electronic and the odometer still works.. is there any suggestions as what to try next ????
Jul 24, 2007 at 8:12 AM
  • 75,988 POSTS
[quote:36762e8df5="goudy316"]i have a 93 aerostar and i just put a used re-end in it and now my speedometer after 80km starts to shift all over.. i have changed the sencor that is on the re-end that goes to the tranny.. and it still does the same thing.. so thats not the problem.. its electronic and the odometer still works.. is there any suggestions as what to try next ????[/quote:36762e8df5]
Go back to the sensor on the tranny make sure its engaging properly-if it does they might be another VSS on the speedometer head
Aug 2, 2007 at 12:24 PM
Suggested Repair
Recheck the transmission speed sensor and confirm it is engaging properly. If engagement is correct, inspect for a second vehicle speed sensor at the speedometer head.
Conversation Summary
The owner of a 1993 Ford Aerostar says the speedometer jumps after about 80 km following installation of a used rear end. Replacing the rear-end sensor did not help; the system is electronic and the odometer still works. The expert advises verifying that the transmission sensor engages properly and, if it does, checking for another VSS at the speedometer head.
