ford aerostar
KAJ419
I have a 1994 aerostar and the headlights just quit working one day. someone said they have circuit breakers, but i can't find them, so i figure its a bad switch. If it is the switch how do i get the knob off so i can get the dash the rest of the way off to replace it. and is there anything else i might need to know.
thanks
kaj419
Mar 29, 2006 at 6:58 AM
PEPPERMRJ
  • 1,158 POSTS
It doesn't come off. You have to remove the dash trim panel and then the left control pod screws and you will see the 2 screws that hold the switch in. Check your PMs.
Good luck and let us lnow. :)
Mar 31, 2006 at 1:15 PM
