1996 Ford Aerostar oil pan gasket
1996 FORD AEROSTAR
KWELD16
Engine Performance problem
1996 Ford Aerostar 4 cyl Two Wheel Drive Automatic
can anyone help with how to replace the oil pan gasket on my 96 aerostar?
Jul 9, 2009 at 11:55 AM
  • 110,244 POSTS
You simply need to remove the oil pan, clean the old gasket material from the pan and engine block, and replace it. Make sure to drain the oil prior to starting. My only concern, is there enough clearance to remove the pan without lifting the engine?
Aug 6, 2009 at 4:27 PM
