1994 Ford Aerostar too much fluid
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSANTOS57
I started having problems with my van going uphill on highways, specially above 60 miles per hour. The van tries to shift continuously when I give more gas in order to keep my speed. When I checked the transmission fluid, I noticed that it was above the full line. Is this causing my problem?
Jan 12, 2009 at 12:48 AM
  • 110,246 POSTS
Hi:
I doubt that is the cause. However, I recommend getting it to the full level. Have the speed sensor checked on the trans.
Jan 16, 2009 at 2:44 PM
GSANTOS57
I suctioned about a quarter of fluid out of the transmission before getting it no normal level, and took the car for a test. Believe it or not, the problem is gone completely. I don't have idea what the relationship of that was to the problem... but it is fixed now.
Jan 17, 2009 at 3:53 AM
  • 110,246 POSTS
Hi:
Anyhing is possible. I'm glad that it's working for you. If you have other questions, let us know.
Jan 18, 2009 at 10:21 AM
