My transmission was leaking trans fluid between the motor and the transmission. So I changed the front seal of my transmission, the whole transmission had to be removed, and a circular metal piece. There were no leaks for 2 days and then at times the trans leaks oil and at times it doesn ´t the mechanic says that because I turn my van on in neutral gear that it damages the seal is that true? ¿? Why is the trans still leaking?
SPONSORED LINKS
Monday, June 30th, 2008 AT 8:52 PM
