HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aerostar
Drivetrain
Transfer Case
SPONSORED LINKS
1993 Ford Aerostar
DAVID SLUDER
MEMBER
1993 FORD AEROSTAR
Brakes problem
1993 Ford Aerostar 4 cyl Front Wheel Drive Automatic
my rear breaks when I come to a stop one of my rear tires drags on the ground making a terrible screaching sound
Friday, August 15th, 2008 AT 7:07 AM
KHLOW2008
MECHANIC
Hi david,
Your brake system is not working well and the wheel that is dragging is locking up.
You need to service/check the brake system, especially the calipers/pistons
SPONSORED LINKS
Saturday, August 16th, 2008 AT 11:31 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1995 Ford Aerostar
Transmission Problem 1995 Ford Aerostar 4 Cyl Front Wheel Drive Automatic 123k Miles Shift Lever On Column Shifter Is Loose & Sloppy...
Asked by
mikefor
1 ANSWER
1995
FORD AEROSTAR
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
Rear Wheel Bearings Loose On 1991 Aerostar Van
Can I Tighten Up Rear Wheel Bearings On 1991 Aerostar Van
Asked by
tintrucker
1 ANSWER
1991
FORD AEROSTAR
1995 Ford Aerostar Cv Boot Replacement
I Have A Torn Cv Boot And Need To Replace It. I Need To Know 1) Can I Reuse The Hub? 2) Are There Different Types Of Boots? 3) Is The Axle...
Asked by
shanaka
1 ANSWER
1995
FORD AEROSTAR
SPONSORED LINKS
Driveshaft Removal
Transmission Replacement - Automatic RWD
Bearing Hub Replacement
Online car repair manuals
