1995 Ford Aerostar
1995 FORD AEROSTAR
MIKEFOR
Transmission problem
1995 Ford Aerostar 4 cyl Front Wheel Drive Automatic 123K miles
Shift lever on column shifter is loose & sloppy when
shifting from Park to Drive & rest of detents. I have to jiggle shift lever in order to get park position & start vehicle.
Aug 11, 2010 at 6:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
A loose gear selector is most commonly caused by worn shifter bushings. These bushings are in the steering column and require that the column be removed from the vehicle.
Aug 11, 2010 at 6:24 PM
