1987 Ford Aerostar not sure why it wont run
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARKELDO
the van was running then quit, just wouldnt start. it will start with starting fluid sprayed in the intake,but wont stay running, the fuel pump runs when i jump power to it, but still wont start without starting fluid. could the injectors not be working?
Aug 19, 2009 at 9:21 AM
  • 75,988 POSTS
Check the fuel pressure with a gauge to rule out the fuel pump and also could be the injectors not pulsing.
Aug 19, 2009 at 10:49 AM
MARKELDO
the pressure is good from the fuel pump, what would cause the injectors not to pulse?
Aug 19, 2009 at 11:24 AM
  • 75,988 POSTS
The computer's injector/s ground drivers.
Aug 19, 2009 at 11:41 AM
MARKELDO
so the computer needs replacing or is it repairable? where is it located?
Aug 24, 2009 at 12:19 PM
  • 75,988 POSTS
The computer is located under left side of the dash above wheelwell
Aug 24, 2009 at 12:26 PM
