1995 Ford Probe No Start After Sitting
SOMETHINGSWEET49
I have a 1995 ford probe with a v6 with about 60000 miles. The car had been sitting for about five years, and i went to move it, and it wouldnt start. i gave it some eather and it started and ran for a minute but shut back off. i'm thinking that its the fuel filter, but i want your opinion.
Apr 24, 2007 at 2:06 PM
SERVICE WRITER
  • 9,123 POSTS
Certainly sounds like its fuel related. Might be a filter, might be a pump, might be neither.
Need to see if there is any fuel pressure, may need to pull the filter and then check pressure again. IF none, need to check for power getting to the pump.
Apr 24, 2007 at 2:18 PM
Suggested Repair
Check fuel pressure. If there is none, remove the fuel filter and recheck pressure. If pressure is still absent, verify that power is reaching the fuel pump.
Conversation Summary
The owner of a 1995 Ford Probe V6 that had sat for about five years says it would not start. Starting fluid got it running briefly before it shut off, and they suspect the fuel filter. The expert says the problem sounds fuel-related and recommends checking fuel pressure, possibly after removing the filter, then checking power to the pump if there is still no pressure.
