1989 Ford Probe No Spark No Start
KEVINGRIFFIN
I have a 1989 Ford Probe GT with a 2.2 turbo 4 cyl. Car has 145,000 Km's. Engine does not start! Have verified fuel & air as good. Spark plugs are not getting voltage from coil. Have verified that coil is good and that 12VDC switched is present at coil. Have tried a new coil for the heck of it with no new luck.
Where chould I look next?
Kevin...
Jan 2, 2007 at 2:56 AM
BRUCE HUNT
  • 3,754 POSTS
Probably the Ignition Control Module.
Jan 2, 2007 at 3:44 AM
KEVINGRIFFIN
Finally got to fixing this. For the record the fault was in the fuse panel. After further fault finding, voltage at the coil was dropping to 2VDC when the engine was cranked. The engine fuse clip in the fuse panel had a crack. When current was demanded, the clip was breaking contact with the fuse.
Kevin...
Jan 13, 2007 at 10:33 PM
Suggested Repair
Repair or replace the cracked engine fuse clip in the fuse panel so the coil keeps full voltage while cranking. If that circuit is sound, check the ignition control module.
Conversation Summary
A 1989 Ford Probe GT 2.2 turbo would not start. Fuel and air were verified, the coil tested good, and switched 12V was present at the coil, but the plugs had no spark. An expert suggested the ignition control module. Further testing showed coil voltage dropping to about 2V while cranking because a cracked engine fuse clip in the fuse panel lost contact under load.
