1991 Ford Mustang No Start Popping
VICTOR1978
1991 mustand gt 5.0 302 ford five speed manual trans. i changed out my valve cover gasckets. and intake gaskets as well. i removed the distributor in the process. i marked it in place thus to put it back in the same place . everything was put back in order even the dissconected gas line rails. the car will not start. it just pops and cranks over. i looked at everything twice i even cleaned the intake completly before putting it back on. i put my distributor back in the same locatin as well. this car had never given me any problems at all it just idols and crancks a lot. i checked the fuel line and presure its ok.
Apr 14, 2007 at 6:10 PM
MERLIN2021
  • 17,250 POSTS
Take the distributor out and set the engine 1 cyl. to top dead center, put the dist. back in with #1 firing! Popping indicates timming problem! Or check your wires, you may have crossed a few of them!
Apr 15, 2007 at 2:03 AM
Suggested Repair
Remove the distributor, set cylinder 1 to top dead center, and reinstall it so it fires on cylinder 1. Popping indicates a timing problem. Also verify the spark plug wires are not crossed.
Conversation Summary
The owner of a 1991 Ford Mustang GT 5.0 replaced the valve cover and intake gaskets and removed the distributor, marking its position before reinstalling it. After reassembly the engine cranks and pops but will not start, though fuel pressure is okay. The expert says popping indicates a timing problem and advises setting cylinder 1 to top dead center, reinstalling the distributor so number 1 fires, and checking that plug wires were not crossed.
