Air conditioner issue
FIXITMR
  • 9,990 POSTS
Also pass rear window regulator is not working right motor works did it pop outa track or something?
Monday, August 15th, 2016 AT 12:49 PM
FIXITMR
  • 9,990 POSTS
So anyway I added 2 cans of freon and it works again! I mean it lasted like 6 hrs so far. Will know more in morning.
Monday, August 15th, 2016 AT 10:28 PM
SATURNTECH9
  • 30,869 POSTS
Get a spray bottle and put some liquid soap in it then add water Spray all around everywhere including that hose by the exhaust manifold. Look for bubbles. Also for the rear window the plastic slider in the window regulator breaks. Saturn used to sell the sliders to fix the regulator.
Tuesday, August 16th, 2016 AT 5:51 AM
FIXITMR
  • 9,990 POSTS
Worked this afternoon. Yah I sprayed some windex on lowP hose and fittings when I added the freon didn't see anything but maybe windex is not the right stuff to use. It was handy at the time.
Tuesday, August 16th, 2016 AT 1:49 PM
SATURNTECH9
  • 30,869 POSTS
Soap and water with lots of soap
Tuesday, August 16th, 2016 AT 2:00 PM
FIXITMR
  • 9,990 POSTS
Funny thing was when I went to poke high side port the valve needle wouldnt budge?
Tuesday, August 16th, 2016 AT 7:23 PM
SATURNTECH9
  • 30,869 POSTS
No idea it's really safe to do that poking. They don't really freeze up from what I see.
Tuesday, August 16th, 2016 AT 7:45 PM
FIXITMR
  • 9,990 POSTS
Still cooling/working
Sunday, August 21st, 2016 AT 6:42 PM
FIXITMR
  • 9,990 POSTS
Heres a strange 1. Someone says they put way to much oil in a 2002 kia spectra and it was smoking bad. Dont know how long they drove it that way. Then they corrected the oil level and they say it still smokes too much. Dont know how long they drove it after correction. They are selling it cheap. My thoughts are it may clear up with enough driving? I didnt see anything on net about kia oil burners.
Sunday, August 21st, 2016 AT 6:47 PM
SATURNTECH9
  • 30,869 POSTS
Usually once you correct the over fill it will stop smoking after driving a while.
Sunday, August 21st, 2016 AT 7:13 PM
