1997 Saturn SL2 No cold air
RADRUDE
  • 1997 SATURN SL2
  • 4 CYL
  • FWD
  • 150,000 MILES
This car was given to me by a family member. The A/C does not blow cold air at all. Could it be that it needs freon or is it that the compressor is out. How can I tell if the compressor is not working at all? Also the power door locks are not working. Could it just be a blown fuse or something more costly? Could these two things be related? How much do you think this would cost me to get these things fixed? Should I go to a saturn dealership or find a small garage that will fix it? One more thing, the car sometimes does not want to turn over ont he first try. Somtimes it takes three tries. Could it be the starter going out or ignition switch or just fowled spark plugs?
Tuesday, September 1st, 2009 AT 1:03 AM
Car's air conditioner blowing warm air only and no cool air? Your A/C cooling problem could be caused by any of the following:
Your A/C system may have lost its charge of refrigerant, or the compressor may not be engaging when you turn on the A/C, or the blend air door inside the HVAC unit may be stuck in the HEAT position so no air goes through the A/C evaporator.
Start with the compressor. Does it engage when you turn on the A/C?
If so, the compressor is working and the A/C system probably contains enough refrigerant to make cold air, so the problem is inside the HVAC unit. Replace the motor that controls the blend air door (this is a difficult job and best left to a professional since it involves tearing apart the HVAC unit -- about an 8 to 10 hour job!).
If the compressor does not engage when you turn on the A/C, see if it will run by jumping the compressor clutch wire directly to the battery (use a fused jumper wire). If the compressor works when you jump it, and the A/C blows cold air, the system contains refrigerant and the fault is likely a bad A/C compressor clutch relay or a bad clutch cycling switch or pressure switch.
If the compressor does not engage when you jump it, the problem is a bad compressor clutch.
If the clutch engages but the compressor does not turn (the belt will start to slip and squeal), the compressor is loced up and you need a new compressor.
If the compressor clutch engages and turns the compressor, but the A/C still does not blow cold air, the system is probably low on refrigerant and needs to be recharged. If you Have an A/C gauge set, hook it up and see if the system has any pressure.
If it is out of refrigerant or is low, check for leaks, then have the A/C system vacuum purged to remove air. After the air is out, it can be recharged with the specified amount of refrigerant. It is important to get any air out as this will reduce cooling efficiency and may make the compressor noisy.
My advice to you if you know nothing about A/C service is to find a repair shop that specializes in A/C repairs and let them fix your cooling problem for you. Today's A/C systems with automatic climate control are very complex and reuire special tools and know-how to diagnose and repair.
Tuesday, September 1st, 2009 AT 3:30 AM
