Flooded engine
169,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
KARLOSHICKS18
I have had the car for about two or three months, ever since i have gotten the car the spark plugs and the engine seem to always get flooded out with fuel, causing a crank no start. i have change little things over time such the crank and cam shaft sensors, fuel pump, ignition coils, fuel injectors, and the fuel line. i have taken the car to a shop and my mechanic ran a diagnostic and couldn't pinpoint why the spark plugs constantly get flooded out. any new advice would be appreciated.
Jul 2, 2019 at 12:16 AM
Good morning,
What makes you believe it is a fuel delivery issue?
Has anyone verified spark when it would not start?
Are there any codes stored in the system?
Jul 2, 2019 at 12:24 AM
KARLOSHICKS18
i don't have any codes at all surprisingly, usually i’d have a lingering p0420 code. i can take all the spark plugs out and they’re soaked in fuel and when i look down the chambers i see puddles of fuel in each one. i tested out the spark plugs when i dried them off and was able to confirm they are definitely getting spark.
Jul 2, 2019 at 1:43 AM
Okay, if you have spark and fuel, check the compression to see if the valve timing is correct.
Jul 2, 2019 at 1:47 AM
