Flashing check engine light
STEVE W.
  • 13,588 POSTS
That will cause the misfire. Good job finding it. Unfortunately you got hit with the binding valve stem issue. What likely happened was that you stepped down on the gas, the valve opened and had a slight bounce which caused it to bind, the piston came up and pushed it back into place, but now the bent stem was enough that the pushrod bent when it tried to move the valve again. Wouldn't be the first time. What I normally do with them is to pull the head off, remove the guide, install a new one, cut the seat and lap in a new valve. Or because they are sort of a known issue I'll even run a reamer set at the proper size for the guides bore and run it through them, just to be sure they are clear and round. Then do a valve job on the head.
Friday, September 25th, 2020 AT 8:08 PM
GEORGE RHODES
  • 21 POSTS
The top of the piston has a little scuff mark where it pushed back the valve but looks okay. I'm buying a remanufactured head and putting it back together.
Wednesday, September 30th, 2020 AT 7:11 PM
STEVE W.
  • 13,588 POSTS
Sounds like a plan. That is basically what I do in the shop if possible. I would likely pull the other side off and clean and lap that side just to check it and maybe avoid a similar problem there.
Wednesday, September 30th, 2020 AT 7:28 PM
GEORGE RHODES
  • 21 POSTS
I pulled the other side replaced valve seals and gasket. Thanks so much.
Thursday, October 1st, 2020 AT 5:09 PM
STEVE W.
  • 13,588 POSTS
Thank you for using 2CarPros. Please return anytime with your automotive questions, and thank you for the updates.
Thursday, October 1st, 2020 AT 6:46 PM
