2024 Citroen Dispatch Rocker Cover Gasket Fix
104,000 MILES • 1.9L • MANUAL • DIESEL
GWYN POWELL
The new rocker cover comes with pre installed gasket for the main part of the unit but does it require a separate gasket or sealant for the paving valve oil separation
Nov 4, 2026 at 5:52 AM
  • 55,849 POSTS
You are good to go, you don need another gasket, you can use a small amount of gasket sealer but do not clog the oil relief passages. Let me know if you need anything else.
Nov 5, 2026 at 9:04 AM
Suggested Repair
No separate gasket is required for the oil separator. A small amount of gasket sealer may be used, but do not clog the oil relief passages.
Conversation Summary
The owner of a 2024 Citroen Dispatch asked whether a new rocker cover with a preinstalled main gasket needs a separate gasket or sealant at the oil separator. The expert said no additional gasket is needed and that a small amount of sealer is acceptable if the oil relief passages are not clogged.
