Thanx
1998 Cadillac Catera Valve Cover Gasket Leak Fix
Thanx
Suggested Repair
Valve cover gaskets are inexpensive; most of the cost is labor. A knowledgeable DIY mechanic can replace them by removing the valve covers, fully cleaning off the old gasket so the surface is smooth and level while keeping debris out of the valves, installing new gaskets, and applying even pressure along the cover for a proper seal.
Conversation Summary
The owner of a 1998 Cadillac Catera reported a slight oil leak from the valve cover gaskets, questioned a $595 dealer quote, and asked whether a weekend mechanic could do the job. The expert said the gaskets are cheap and the quote is mostly labor. The job is not especially hard but needs some engine knowledge: remove the covers, clean the old gasket material for a smooth level surface, keep debris out of the valves, install the new gaskets, and apply even pressure for a proper seal.
