Exhaust modification
185,000 MILES • 5.7L • V8 • 2WD • MANUAL
JACKNUT
  • 65 POSTS
Can I run straight pipe from y pipe to rear bumper. I wanted to cut y pipe and make true duals. Can I do that? I just put on Shorty headers?
Apr 10, 2019 at 9:48 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes you can. Most dual exhaust will have a crossover in the middle. It can be an "X" but most are a "H" crossover. This helps with keeping the exhaust balanced. You can usually find premade X and H crossovers on Ebay pretty inexpensively, and in different diameters depending on your exhaust systems requirements.
Thanks,
Alex
2CarPros
Apr 11, 2019 at 2:53 AM
JACKNUT
  • 65 POSTS
What about true dual exhaust? where can I get the pipes that will not to the Shorty headers?
Apr 11, 2019 at 5:58 PM
SCGRANTURISMO
  • 4,897 POSTS
You can. This is how your vehicle's exhaust system breaks down: The exhaust manifold (which your shorty headers are the same size as your exhaust manifold). next comes the mid-pipes, you will have to replace this part of your exhaust or modify it to move from a Y pipe to dual exhaust. The last part of the exhaust system is the catback. this is from the mid-pipes to the exhaust tips. You will have to replace this or modify it to go to dual exhaust. Look online at Amazon or Ebay for full length mid-pipes, and any catbacks for your vehicle. Catback systems are usually all the mufflers. I hope this helps.
Thanks,
Alex
2CarPros
Apr 12, 2019 at 4:34 AM
